n plot multi chart
I'm trying to create a muilt chart starting with an array of n floats.  Each float is to be plotted as a separate plot on one chart.  For example, if the array is 5 elements long, the the chart will have 5 plots.  I can find examples of how to plot multicharts if you know ahead of time how many plots there are.  These example just brute force the solution by creating a bundle or build array element for each entry.  I've been trying to construct the equivalent using for loops, but every attempt ends up with labview interpreting the data as many points in a single plot.  For example, if I have 5 elements labview plots it as 5 points of one plot, not 5 plots of 1 point.  Any ideas?
(4,402 Views)
Accepted by topic author Jim12345678
Go figure.  I worked it out about a minute after posting the question.  Much simplier than I thought.
(4,389 Views)
Hi Jim,
what a bunch of RubeGoldbergs…
Why not this way:
(4,377 Views)
Tried that, but it was interprted as 1 plot of n points not n plots of 1 point.
(4,358 Views)
Hi Jim,
please use TransposeArray instead of your RubeGoldberg constructs!
(4,343 Views)
