naming wires
Hi!
I have a stupid question, which i dont seem to find an answer to.
How can i put a label to my wires?
On Labview coursepapers they show >wire name> above the wires, but cant seem to find anything how to label them.
Thanks in advance.
(5,541 Views)
On the diagram
    1. press "shift" and right-clic at the same time, the tool palette will appear,
    2. select "text tool" (as shown on the picture)
    3. then place your text over a wire, clic and type..
you can't set a proper name for a wire like you do for a control or indicator...
Hope this helps 😉
Message Edité par TiTou le 11-24-2006 03:30 PM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(5,537 Views)
Yeh.
This i allready knew, but thought there would be some "smarter" way for naming the wires.
(5,529 Views)
Second to novels by Greg McKaskle and similar, I think I learn most from trying to find exceptions to "you can't" replies by some our top contributors. Smiley Wink
Right click on the wire and choose Description and tips to associate text with a wire.
The text is only visable in the help window (ctrl-h) with the wiring tool selected.
Smiley Happy
Technically, I believe TiTou is correct. I only went poking around when I recalled I had posted a product suggestion that would aide in scripting in the event it ever gets released in a supported form.
Ben
Message Edited by Ben on 11-24-2006 09:33 AM
(5,518 Views)
Smiley Surprised
Thanks for the trick ben 😉
And you are right, I definitely have to teach myself not to say "you can't do this"  Smiley Sad
I'm working on it..
Epictetus
Antoine Chalons
(5,512 Views)
Hi TiTou,
This is just TOO appropriate not to mention.
In this thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=125137&query.id=520098#M125137
CC wrote;
As you are probably aware, frenchies are not humble people ... We even have a proverb saying that "impossible n'est pas francais"
(emphesis added)
Ben
(5,502 Views)
That is so terribly true.... Smiley Very Happy
Epictetus
Antoine Chalons
(5,494 Views)
