national instruments windows event viewer "msinstaller"
I have a windows 10, 64bit computer. Is it normal that my windows event log shows a daily product reconfiguration of all national instruments components? If it is, then it must be a new feature because I don't see it on my windows 7 laptop. I have attached a screenshot.
It does everyday around the same time for hundreds of NI components and last about 10-20 seconds.
thank you.
Certified LabVIEW Developer
(3,111 Views)
I checked on my computer's windows event log and there's no daily reconfiguration (same Operating system, same LabVIEW (to name one NI software)), so it doesn't seem a feature.
Does it happen with all downloaded software or just NI's? If it happens with all probably more a Windows issue.
Also is your computer an HP computer? I've seen that this happens in them. If it is, take a look at the ninth post here, by AnEdge https://www.tenforums.com/software-apps/31460-successful-application-reconfiguration.html
Hope this helps!
(3,067 Views)
Hi cdiaz95,
Thanks for the response!
You're right, it's not only for NI components, there's other things as well (e.g. MS office, measurement studio, visual c++, etc.)
It's actually a dell rack mount computer (Dell precision rack 7910).
Don't know if reinstalling labview will do any good, like you said, it could be a windows issue.
Guess i'll ask my IT department and see if they have any ideas. Cross fingers ><
(3,062 Views)
Yeah I wouldn't uninstall LabVIEW or any NI hardware, seems too much trouble for the unlikeliness of it fixing the issue.
Definitely asking IT seems a good idea, I'd also make this question or search for similar questions in Windows's forums.
Good luck!
(3,055 Views)
