ncConfigCANnet
Hi Guys, i have made a vi to get readings from a 9862 module. i run this to my PC and it works perfect. I have built also an exe that is also works ok in my PC but  when i try to run it to another PC i get an error message. (please find it attached)
looking forward to hearing from you
Elias
(3,131 Views)
Does the CAN device/port on the other PC have the same interface number as on your PC?
Try to go to MAX and see what the interface number is for both PC's.
Right now the error tells you that the interface number (CAN0, CAN1 ....) that you have giving in the code is not valid for the other PC.
(3,114 Views)
Yes it is the same! i got it also as a control and i tried it in several interface numbers in order to be sure that this is not the case.
thanks for your reply
Elias
(3,111 Views)
