.nce file
I am trying to open a .nce file in MAX but I get an error. This is the description of the error report - ******************************************************************************************************************************************************************************* Date: 12/16/2008 5:36:06 PM User: mylaar File: D:\MAX18012008.NCE File version: 4.0.0.3010 MAX version: 4.5 Importing... ======== NI-VISA 4.4: General Settings VISA Alias (LPT1) VISA Alias (COM3) Port Settings Port Settings VISA Server Security NI-DAQmx 8.7: -201028 Measurements: Name specified is already in use. Specify a name that is not currently in use. Property: Name Value: Dev2 *** Import FAILED *** NI-DAQmx 8.7: error code 0x80004005 ****************************************************************************************************************************************************************************** I am able to open this file in excel but I dont know how to get into MAX. I have tried opening in 4 to 5 computers but I am getting the same error. Please suggest me what to do. Thanks a lot in advance. Regards, mylaar
(4,476 Views)
Have you tried renaming your hardware?  I have code in my .nce files that only works if my hardware is named "Dev1", but NI MAX auto names hardware when it 1st connects to a new computer, so I end up renaming my hardware every time I switch computers.  It looks like you have or have had some hardware called "Dev2" witch is one of NI MAX's auto genorated hardware names.
(3,913 Views)
(3,904 Views)
