need a control
I have a ring control for fixed values of gain 1, 2, 5, 10 and time 0.1,
0.2, 0.5, 1, 2, 5, 10 sec.
How can I access instead of the enumerated value to the associated string or
the corresponding numeric value.
Peter Nyffeler mailto:nyffeler@phys.chem.ethz.ch
Tel P 01 363 62 42, Tel G 01 632 43 60, Fax G 01 632 10 21
(3,200 Views)
Peter;
To access the associated string, create a property node and read the String[] property, which is an array of the text items in the ring control. Use the current value of the ring to obtain the corresponding string.
Also, check "Create G enum from C enum statement numCtoG.vi" in Drolet's LabVIEW Bestiary. It can be what you need.
Regards;
Enrique
PD: Sometimes I think NI should consider a function to do something similar to what Drolet did in his numCtoG vi. It is very useful.
www.vartortech.com
(3,200 Views)
In article <5065000000050000005D7A0000-1021771306000@exchange.ni.com>, Enrique wrote:
Enrique,
Thank you for your answer.
That is exactly what I was looking for.
May be you can help me on some other points.
1.a Is there a way to see the current value of all property nodes of an
object?
1.b By try and error I changed some properties by mistake.
Can they be reset to values as when taken from the controls palette?
2. On a chart I need increments other than 1 e.g 0.2.
Which the property node name
for scaling factor dX?
With best regards
Peter
(3,200 Views)
May be this document also help you a little bit...
Creating a Text Ring Control for LabVIEW with Arbitrary Label/Value Pairs:
http://zone.ni.com/devzone/conceptd.nsf/webmain/A1825BF0A8BEB8CD862569B5000D0BB0?OpenDocument
You can see result in attached VI
(3,200 Views)
