need buffer
                        New to labview but had a quick question.  I have a vi that outputs a float number each time it is executed and I have a graph that is looking for a 1 dimensional array.  Would a structure work to capture the vi outputs and how do I set up a temp buffer to hold the data that goes to the graph?
(3,768 Views)
You could use a waveform chart instead of a graph as the chart has a built-in buffer. Thus, you just need to wire the output of your VI directly to the chart. You can configure the buffer size for the graph (right-click on it and set the history length). If you have to use a waveform graph then you could use a shift register as your buffer if you have a loop (which I assume you do). Or, you could use an Action Engine as your buffer implementation.
(3,763 Views)
ok thanks for the quick response, will try a few of the suggestions.
(3,760 Views)
 This is the simple buffer VI available with LabVIEW,You simply modify according to ur need.
Message Edited by Baji on 05-28-2009 09:09 AM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,736 Views)
