need counter my way not yours
I have a vi, written in 6.1. with several do whiles, several for next, ya-da ya-da - ya-da.
What I need is a counter, that Increments every time the set of sub vi's are finished, and this counts need to increment just before I am about to go back to the begenning.
An example in basic would be a=a+1: print a
no ms, no computer counter, no external counter, just something to tell me how many times my software has started over.
Steve
(2,484 Views)
If your code has an outer most while loop (which if it runs multiple times, I suspect it would) just put your "a=a+1" (shift register with a "increment" primitive tied to it) there and wire it to an idicator as the last thing it does before looping back to the beginning.
If you need a visual I could whip up an example pretty quickly.
Good luck.
(2,486 Views)
