need direction on fairly basic program
I am a summer intern helping automate a lab experiment. If I were doing this in C++ I would be able to complete the task fairly easy, however I am using labview and am having trouble adapting to this syntax.
what I am trying to do is give directions to a camera to take pictures at an interval of every 15 seconds. I am to find the length of a certain feature of an image, and this length grows with time and then output this data to a excel spreadsheet, simply place the length along with the time. this is to be done several times (a loop).
I have already figured out the image analysis part through the use of various filters in the NI vision assistant program. I have converted this to a labview VI, and want to insert it into a loop such that it would be completed several times.
can anyone give me any direction as to where to look for more information that is more specific to the task i'm trying to complete?
I have included a diagram that may help to illustrate what im doing, it is rudimentary (sorry).
thanks for any help
(3,688 Views)
I came from a text-based background too...  I think you'll find that most of the things you're used to in those languages are in LabVIEW, just maybe in a different form.
For your loop, use a for loop structures->for loop.  Wire 200 to the N in the top left corner (number of iterations)
Then place your sub vi in there and then use time & dialog->wait.  Wire 20 000 to the wait function, as it count milliseconds
And you should be set...at least as far as your image is concerned
(3,678 Views)
When you get something together post it and we'll be glad to help you get it structured right.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,671 Views)
here it is, I sincerely apologize for the elementary-ness of this VI. but here it is.
thanks!
(3,649 Views)
Kirkland,
The vi looks good.  All you just need to wire 20000 to the wait vi that is inside your loop and you dont need the wait function that is outside your loop.  The wait inside the loop will cause the loop to wait every loop, whereas the wait outside the loop would just cause one wait when you first run the vi which makes sense because its outside the loop and not associated with it.
Brian
it should look like this
(3,633 Views)
Thank you for the reply that was very helpful. How may I tell the VI to take the snapped image to my analysis subVI, and then save the final piece of data from the subVI to something like an excel spreadsheet?
And I apologize if these are questions easily answered through other means, in that case I would appreciate it if you could simply direct me to those means so I wouldn't be wasting anyone's time.
thanks
(3,620 Views)
