need help for average
Hi, I am compiling a program by using Labview. I get one 2D Array after 2 loops : one is inside and the other is outside loop. Right now, what I want to do is to find the mean values of the every cell in the array after measurement eg. [1, 2, 3] - first try; [1.1, 2.01, 2.99] -second try; [0.9, 2.1, 3.1] - and so on and the averaged signal that I want to get is [mean(1, 1.1, 0.9) ; mean(2, 2.01, 2.1) ; mean(3, 2.99, 3.1)].I can't suceed in getting the right result. Please helpe me.
(3,062 Views)
Probably all you need to do is transpose the 2D array and feed that into a for loop with the mean function inside. In the attached example, the inner for loop simulates something like taking a reading from ch1, then ch2, and then ch3. The outer for loop would be for taking 3 readings of each channel. The final array is the mean for each channel.
(3,062 Views)
Hi, Dennis Knutson,
Thank you for your answer so soon. But your labview version is 6.1 and mine is 6.0, so I can't read your example. Can you give me the example on labview version 6.0 or transfer your example from the version 6.1 to 6.0?
Thanks again.
Whuili
(3,062 Views)
(3,062 Views)
Hi, Dennis Koutson,
I get it and have succeed in this program. Thanks a lot.
Whuili
(3,062 Views)
