need help in tab control
Hi
I have tow VIs , I want to put them in tab control , the first Vi in the page one and the second in the Page 2 to run sparat , should I copy and paste the code of Vi on the page ?
how can I use tab control
Message 1 of 9
(4,022 Views)
A tab control is a front panel structure, typically used cosmetically to group and simplify elements of the ui. The way VIs run is decided in the diagram. Can you clarify what you actually mean?
Message 2 of 9
(4,015 Views)
Subpanels.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019OX6SAM&l=en-US
https://www.ni.com/docs/en-US/bundle/labview/page/loading-a-front-panel-in-a-subpanel-control.html
Jim
Message 3 of 9
(3,999 Views)
I was initially thinking subpanels too, but then you would definitely not "copy and paste" code.... The question makes no sense. 😉
Message 4 of 9
(3,990 Views)
I am sorry if I could dont be clear
the subpanel diffrent than the tap control ,
the why I want to use tap control ? I have two diffrent tests (with the diffrent VIs) for the same sample , I want to run the first test when I press page 1 on the tap control and then I run the second test when I press page 2 on the same tab control .
Message 5 of 9
(3,955 Views)
It would be much more clear if you could attach your VI.
Message 6 of 9
(3,951 Views)
I hope I will be clear now
Message 7 of 9
(3,947 Views)
This is really horrible, but here's the basic idea.  Put the code for each test inside the Case Structure in the Event Structure handling the Value Change event.  If you're planning to write a State Machine you can have this event send the execution to a particular state.
Jim
Message 8 of 9
(3,942 Views)
VIs dont go on tab controls.
You would place regular controls and indicators that get wired to the subVIs on the diagram. You can use a case structure wired to the tab control terminal to change which subVI gets executed.
Message 9 of 9
(3,939 Views)
