need help to split a string
Hello All,
I am getting data like -4.11139E-06-2.20064E-013.15263E+01-1.18792E-05-3.72294E-025.50947E+024.60728E-05-1.00468E-01-1.07451E-08431-50-628-03.
I want to split this string to
a = -4.11139E-06
b = -2.20064E-01
c =  3.15263E+01
d = -1.18792E-05
e = -3.72294E-02
f = 5.50947E+02
g = 4.60728E-05
h = -1.00468E-01
i = -1.07451E-08
Then ignore 431-50-628-03 from the output.
Thank you very much in advance.
Message 1 of 9
(4,641 Views)
Accepted by topic author aro1
try this
EDIT: remove the ? from the string.
Ben64
Message 2 of 9
(4,628 Views)
What are you getting that output from?  Maybe we can fix it before you get it as this string.
Message 3 of 9
(4,608 Views)
The good thing is that the numbers in the string all have the same format - they end in E+xy or E-xy.  So you can search for the E and then extract the next three values.  Then put the remaining string into a shift register of a While loop and iterate on it until there are no more E's.  Take a look at my example.
Steve
Message 4 of 9
(4,583 Views)
All,
Thanks for the assistance. The proposed solutions from Ben64 and Steve_G are pricesly what I was looking for.
Ben64, just a note, the code works like I want it to with the "?". When the "?" is excluded, about 3 of the last elements are not picked
Message 5 of 9
(4,542 Views)
I was talking about the ? in the string control on the front panel, not the ? in the string constant on the block diagram.
Ben64
Message 6 of 9
(4,532 Views)
Oh, you did not attach a VI, or screenshot of the front panel, to your initial response. So I could not tell exactly what you had in the string control. I just used my values.
Message 7 of 9
(4,526 Views)
The picture is a snippet, you can drag and drop it in a block diagram to recreate the VI (note that you may have to copy it on your desktop, or somewhere else, before moving it to a block diagram.
Ben64
Message 8 of 9
(4,518 Views)
Oh that's a useful and convenient feature. Thank you for pointing that out.
Message 9 of 9
(4,503 Views)
