need help using vision in a .exe
Hello everyone!
I am developing an app to read barcodes. Everything's working fine when trying it in the pc but the application itself must be used in a tablet. I'm using LabVIEW 2015. I have installed the runtime2015, the vision runtime, the adquisition but I am still unable to read the barcode from the tablet. It works except the part of scanning the code. Not sure what could be the reason or what's missing.
Hope you can help me
Thanks in advance
(3,821 Views)
Did you install the drivers?  How did you name the camera in each?
(3,805 Views)
Well Im using the integrated's tablet camera and it is working fine. Do you mean those drivers, the camera ones?
(3,793 Views)
IMAQ/etc.  The drivers LabVIEW uses to talk to the camera.
(3,779 Views)
Yes I did. Take a look at that picture I attached. It just doesn´t read the data. In the pc it does. Data indicator is empty
(3,763 Views)
