need help with multiple plot xy graph
I need your help with my multiple xy graph.
I have don it like in the examples but it does not work. Instead of two plots, there is only one plot with the two data arrays mixed.
What have I done wrong?
Johannes
LabVIEW 7.1
Message Edited by johanneshoer on 10-14-2009 08:07 AM
Greetings Johannes
Using LabVIEW 7.1 and 2009 recently
(6,555 Views)
 I think I found out....
There needs to be two data arrays and one more bundle...
Is it ok like that? I doubt it... although it works
Is there a better way??
Greetings Johannes
(6,546 Views)
this one is really related to that...
(6,543 Views)
I want to get rid of the two arrays.
I simply joined these two arrays into one array and I select an array subset for the xy graph but that does not work.
Now the two data arrays get mixed again in the chart.
I can't see what is wrong. I have tried many things like indexing the array before the xy graph, directly wiring the array to the graph etc. nothing worked.
Please help.
Message Edited by johanneshoer on 10-14-2009 09:45 AM
Greetings Johannes
(6,521 Views)
finaly... after 100000 tries.
It's not yet working 100% correcty, but the chart is now behaving like I want it!
Message Edited by johanneshoer on 10-14-2009 10:33 AM
Greetings Johannes
(6,515 Views)
finished Smiley Happy
Message Edited by johanneshoer on 10-14-2009 10:53 AM
Greetings Johannes
(6,512 Views)
Dear LabVIEW experts,
I would like to know your opinion about my last version. Is it ok or are there stil things to improve?
I wonder why it is so complicate to display multiple data in a graph (indexing the data array, bundling, building the array again)
How much resources (memory & cpu time) does "delete from array" need? I could imagine, that it stresses the CPU, if I have a large array and if I delete the first row.
Are you able to open my 7.1-VIs with your LabVIEW versions (8.0, 8.5, 2009, whatever)?
Johannes
Message Edited by johanneshoer on 10-15-2009 02:44 AM
Greetings Johannes
(6,490 Views)
