need help
 I need a make a program that explores the one-dimensional numeric table and counts the number of values in the table two controls to the range of
Message 1 of 11
(5,476 Views)
So if i understand ik correctly you need to loop true a 1D array with numbers and count the values that are in range of a set of values givin by an input.
I think you need to check the "In Range and Coerce" function from the compare pallet in a autoindexed for loop.
Learning LabVIEW since January 2013
Message 2 of 11
(5,468 Views)
I use while loop box and case structure box...
Message 3 of 11
(5,460 Views)
try to share your code. it will help us solving the problem.
Message 4 of 11
(5,456 Views)
There is what i have done allready.
Message 5 of 11
(5,450 Views)
Hi temes,
you need to check your comparison functions: right now both try to compare for the upper limit...
Btw you can achieve the same without a loop:
When your arrays are large (more than 32767 elements) you should convert the output of the "?1:0" function to I32...
Message 6 of 11
(5,433 Views)
How can I do this by using loop? Like I have start to doing!
Message 7 of 11
(5,377 Views)
Hi temes,
you can do it just like you have shown in your pics - except for the wrong comparison as I told you before...
Message 8 of 11
(5,373 Views)
Can You do and put a picture for that? I can't do this right.
Message 9 of 11
(5,367 Views)
Hi temes,
you're not able to debug your own VI? Really? Even after getting told what's wrong??? Come on...
Spoiler
Message 10 of 11
(5,358 Views)
