need instructions on how to get Quanser working with LabView 7.1
I need information on what LabView modules or addins to install in order to run Quanser (QNET Experiments release 2.2).  LabView 7.1 is loaded but we also have LabView 7.0 if needed.
(2,442 Views)
Hello JND,
The Quanser website indicates that the QNET products are fully compatible with LabVIEW and NI Elvis. However, I could not find more information on any drivers they provide for LabVIEW, so I suggest you contact them directly about this. If they have drivers written for LabVIEW, that should be enough to communicate with the board from LabVIEW. In order to communicate to NI Elvis, you need to install NI-DAQmx and NI ELVIS drivers.
Good luck and best regards,
Shakhina P.
(2,423 Views)
