need pendulum animation vi
hai,
   i am in need of pendulum animated vi.... i tried to customize the control,but it seems too difficult,... i also searched the vis available in discussion forum,..but its not helpingg.....
one of my requirment is..
the movement of pendulum  from left to right  need to be a variable
i am in urgent need of this regard....
thanks in advance
(3,770 Views)
Did you try to look into Picture Control Examples? There you have a line and circle to easily create the pendulum. LabVIEW have some examples in that area, just use Picture Control as key work in the example finder.
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,760 Views)
Just use an xy-graph containing a plot of two points Use big points and a thick lines as needed. See attached animation of a simple example.
Alternatively, you could use also e.g. a plain gauge. Simply make the scale 360 degrees and update the needle as desired.
Message Edited by altenbach on 05-16-2007 07:01 AM
(3,747 Views)
