need some help! I am writing code for a force plate - FX,FY,FZ + moment X, moment Y and momentZ
The ones below are from the Subvi's folder.
Message 31 of 33
(623 Views)
Message 32 of 33
(622 Views)
Thank You for the VI's. However, the program is still loooking for the following VI's,
Excel Get Worksheet.vi
Excel Easy Table.vi
Excel Rename Worksheet.vi
DAQmx Read.vi
DAQmx Start Task.vi
DAQmx Create Channel.vi
DAQmx Clear Task.vi
DAQmx Stop Task.vi
DAQmx Timing.vi
DAQmx Create Virtual Channel.vi
I know this is a lot. If you are unable to locate those vi's that is ok but the vi's that will help my cause will be the first three listed vi's. Thank You for giving me the opportunity to look at your program.
Message 33 of 33
(595 Views)
