need some help.
I need help for this kind of programming. Can someone do this?
Create a program that examines the take turns two dimensional array numerical values, which may be in the range 0-255. Values are compared with a separate control to the given value. If a single array element value is greater than the threshold value will be given to the corresponding point on the indicator table value of 255 On the contrary, given the value 0.
thank you!
Message 1 of 11
(4,258 Views)
Not sure what you need exactly. If code below is not what you are looking for, please post some sample data so we can help you better.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 11
(4,236 Views)
Thanks, but not quite the kind of
Such a program in another 5x5 grid, for example, gives a value from 0-255. In addition, an extra box, which is the threshold value. Table values are compared with a threshold value. If the original number is greater than the threshold value will be set as the final value of 255 If less then 0th
for example
The control numbers 100
1,154, 245.55 -> 0,255,255,0
thanks
Message 3 of 11
(4,227 Views)
Message 4 of 11
(4,223 Views)
Hi Pauli,
ever considered to multiply your "Arvot 0 tai 255" with 255? Guess what the result will be 😄
Message 5 of 11
(4,218 Views)
its only names, means values 0 or 255
Message 6 of 11
(4,215 Views)
Hi Pauli,
the name of that array isn't interesting, but the data is...
Your array contains 0 or 1 values, but you need 0 or 255. I suggested to multply by 255. Don't you now how to multiply or don't you understand that suggestion?
Message 7 of 11
(4,211 Views)
there is no progman back round. i wrote all numbers.
Message 8 of 11
(4,199 Views)
This?
Message 9 of 11
(4,195 Views)
Hi Pauli,
I can't know there's no block diagram when you only show a picture of the FP.
You already had the snippet from aCe to begin with - and by now you already got the solution too...
Remember: when you don't start programming on your own you will not learn to handle LabVEW!
Message 10 of 11
(4,192 Views)
