need to change type of 1-D array of Time stamp to 2-D array of string
hi
Any suggestions?(see the picture). i need to write this value in Excel, but seems to be incompatible formats.
using Labview 2010.
thanks
(2,786 Views)
First, you need to transform the timestamps to strings. There's several ways to do that, have a look at "Format Date/Time String" for instance.
Then you need to insert a "Build Array" to add a dimension to the 1D array. This will result in a 2D array, which you might have to transpose before writing to Excel.
(2,769 Views)
Are you trying to write out a single "row" (or column) in Excel?  As I recall, the LabVIEW Excel reports like to write out "areas", i.e. a 2-D structure.  To write a single row, simply push the 1-D array through "Build Array" (with only the single input) and it creates a suitable 2-D array.  Note to write a single cell, you'd push it through two such Build Array components (once to build a 1-D row, next to build a 2-D "area").
(2,753 Views)
I am trying to get these values in Rows. i will try your suggestion
thanks
(2,737 Views)
