need to compare image
I am new to labview I had downloaded vision recently I need to compare 2 images I had seen examples but I cant able to load image does anyone please help me.And I need to know that does I need to download imaq or any other to load image.
                                          thank you
(2,730 Views)
Think about a Programming Language that you know -- let's say it is C++.  What would be your advice to someone who says "I"m new to C++.  I've downloaded a compiler and an image-processing library.  I need to compare two images ...".  You'd probably say "Spend a month and learn C++".  Well, before tackling a LabVIEW Image Processing task, you need to learn something about LabVIEW.  In the upper right corner of the Forum, there are several suggested Learning Options for LabVIEW.  Spend the time to take as many as you can, use the Web to supplement it as necessary, write some code and test it out, and then come back and ask for specific help with your code that you attach with your post.
Bob Schor
P.S. -- as a quicker alternative, hire a good LabVIEW programmer.
(2,718 Views)
thank you sir i am asking because its my short time project i had downloaded ni vision but confusing in comparing images
(2,685 Views)
