need to create property node (value) for a bunch of controls (same data type) in my front panel in one shot
I need to create property node (value) for a bunch of controls in my front panel in one shot. Is there any way to do this? All the controls are of same data type.
(2,758 Views)
I take it you don't need to make for all controls on the front panel?
Select all the controls you want, right-click->create reference, build array of references, use a property node in an auto-indexing for loop to read all values, handle values from the output array.
Jarle Ekanger, MSc, PhD, CLD
Flow Design Bureau AS
- "The resistance of wires in LabVIEW is not dependent on their length."
(2,754 Views)
I am using a state machine with events, and all these property nodes has to be used inside individual events. Events are handled by different controls ofcourse.
Juvin
(2,750 Views)
Put the refereres in ***** cluster, wire it to the event structure
(2,737 Views)
