need to know how to calculate the friction torque constant of a dc motor
hi
i am using a transfer function to run a dc motor in labview, so i need to know how calculate the friction torque constant of a motor.
I have seen this constant in the following link: http://zone.ni.com/devzone/cda/tut/p/id/6931#toc2
please help me out because i have to use this in my project.
Thank you
Dinesh
(5,530 Views)
There is no way to calculate a friction torque constant.  That is a property of the motor.  You will have to contact your motor manufacturer to see if they have a way to calculate that, or some sort of table or chart for your motor that gives the constant.
(5,521 Views)
thank you very much
(5,509 Views)
It can be done by means of system identification
cosmin
(5,502 Views)
