need to make a xy plotter using labview
i have a vi which has an grayscale edge d now detected image  .now i need to extract the co ordinates of the image and plot the same sequentially in a chart . i have dove it using gcode parsing . but i need to do it with the co ordinates. pls help me
i am working a project to plot the image on a paper. your ideas please !!!!!!!!!!!!!
i firstly need to plot the image given below in the chart likie it is drawing it..
Thank you
(5,218 Views)
You image is already a XY coordinate... use pixels.
Benoit
If you interface your Gcode to a XYZ table using a GRBL, use my toolkit:
https://lavag.org/files/file/303-grbl-11/
Benoit
(5,178 Views)
so i have to use an arduino interfaced with labview right?
(5,167 Views)
fine do u hav any idea on this ? help on generating gcode in labview or any other method to control a cnc machine using labview
(5,141 Views)
Can u elaborate on how i shld use ur grbl vi . i currently need to convert the coordinates to gcode so that i can make the grbl read my gcode.
(5,163 Views)
take a look at that...
https://openbuilds.com/
it is also possible to find free firmware for Arduino if you have all the electronics already.
Alibaba, E-bay is full of low cost kit that allow you to do that.
But what is you real project? university, college or business?
Benoit
(5,161 Views)
Please read  A plea for full words
Then rewrite your message using English.
(5,157 Views)
