nested function within
Hello to all,
I have a function which i am trying to call which in parts calls a function as one of its input paramters. How can I perform this in LV?
This is my function from the dll.
RtxConfigPollingMode(unsigned long PollingInterval, void (*RtxServiceDevices)(void));
ThanksNAdvance
FD
(3,805 Views)
Hi FredFred,
call first the nested function and connect the result of it to the input of the other function.
Mike
(3,782 Views)
Is it something similar to recursion?
- Partha ( CLD until Oct 2027 🙂 )
(3,770 Views)
I guess, that Call by Reference is closest equivalent in LabVIEW for such construction.
Something like that: open reference to RtxServiceDevices VI, then connect this reference to the input of RtxConfigPollingMode VI, and call RtxServiceDevices VI inside of RtxConfigPollingMode VI by reference.
Andrey.
(3,765 Views)
Thanks alot, I will try to do so and let you know of my progress.
(3,746 Views)
Hi FredFred,
what is your question? Did you ask how to create the dll call in LabVIEW, or how to program such a function and create two vis?
Mike
(3,734 Views)
