nested library function call
Is it possible to create a DLL using the LabVIEW Application Builder from a VI that already contains a library function call?
mlloyd
(2,745 Views)
Hi mlloyd,
This should definitely possible. If you dig deep enough, you'll realize that some of our VIs such as DAQmx, signal analysis, etc, use Call Library Function Nodes, and you can build those into a dll, so this should work.
-Sam F, DAQ Marketing Manager
(2,736 Views)
Thanks Sam.  I have successfully been able to build my subVI that uses a Call Library Function Node into a DLL.  It can be done!
mlloyd
(2,732 Views)
