.net Listview control returning wrong label value
I am using .net control ListView in my LabVIEW application and having trouble
reading the label infromation from the listview control.
I have a callback event on the listview control - AfterLabelEdit - and when
this event occurs I read the label value and display it on a single button
dialog box. but the label value returned has only question marks "?"
I am not sure if this is related to some unicode to ascii conversion issue.
I have attached my vi that demonstrates the issue.
Ritesh
(4,155 Views)
Ritesh,
I ran the code and was able to reproduce what you mentioned. I think you're right that it could be related to a unicode to ascii conversion. You can enable Unicode support by including the UseUnicode=True token in the LabVIEW ini file. I recommend reading through this page to get an idea of what additional steps you'll have to do beyond that in order to read the Unicode text.
(4,099 Views)
