.net assertion when using user event refnum in callback vi
Here is where I define the user event and the .net function.
Heres the callback.
And the assertion...
However, this works...
I dont want to use the global though. I'd like to feed the refnum straight into the callback vi.
Any ideas?
(3,432 Views)
Nobody?
(3,414 Views)
I believe this is the problem you're having:
http://digital.ni.com/public.nsf/allkb/2AF19EBDFA4AC82D862576B6006E7FE8?OpenDocument
This was fixed in version 2010.
Let me know if this is not the issue you're having.
FlexRIO & R-Series Product Support Engineer
(3,407 Views)
That may be the case. I'm not at work now so I cant dig into it.
However... the callback works fine as long as I dont pass a user event refnum into the user parameter.
I'm using the user event refnum in the global variable now (inside of the callback vi) and it works.
I'm just trying to avoid using a global.
Thanks for the reply.
[EDIT] I'm passing a string into the user parameter now. So at least that does work.
(3,404 Views)
If you want to download and try this in 2010, you can get that at www.ni.com/src with a 30 day trial.
Otherwise, if you wanted to upload something that I can test in 2010, I'd be happy to do that for you.
(3,383 Views)
Yeah, I'll do that. It will be Monday morning though.
Thanks Dave!
(3,378 Views)
