.net dll uncompatibility
hello
when I call DLL generated form a visual studio solution, inside a constructor node, I get the following message:
"an error occured at assembly load"
do you have any idea of the cause?
please find joined the DLL
thanks in advance
Pierre FCentum TNS, Grenoble
Certified LabVIEW Associated Developer
(2,537 Views)
A quick google search for your error message revealed several previous questions identical to your problem (posts on this very forum). I assume you have worked through the solutions proposed for these?
http://forums.ni.com/t5/LabVIEW/LabVIEW-2013-An-error-occured-trying-to-load-the-assembly/td-p/27491...
http://forums.ni.com/t5/LabVIEW/Loading-NET-4-0-assembly/td-p/2162212
... etc
(2,496 Views)
