.net framework component error after upgrading to LabVIEW 8.6
The progressbar .NET component don't work after I upgrading my labview 8.5.1 to labview 8.6 (professional development).
Here I attached the vi and the error message screenshot.
It don't work for both labVIEW 8.5.1 and labVIEW 8.6. Both 8.5 and 8.6 work properly if don't have any .NET component inside the VIs.
I have repair my .NET framework 3.5. And it still can't work although I have restarted my PC. Please help. Thanks in advance.
Message 1 of 11
(5,976 Views)
I made some change.  It works now on my laptop.
George Zou
http://www.geocities.com/gzou999
George Zou
Message 2 of 11
(5,942 Views)
Hi Engwei
I did a quick search of the forum and I found this thread, which I think could be useful. There are a couple of nice examples of how you can create a progress bar with sliding scales as opposed to .NET components, I hope you this is helpful! I'll keep looking though to see if I can find the reason why the .NET progress bar causes such an error.
Best regards
Jeremy T
Technical Marketing
NI
Message 3 of 11
(5,941 Views)
I mean, once I run the .NET component, the error message will prompt out. And I worry if I will use other kind of .NET component in the future.
Anyway, thanks for giving your wonderful idea. I will look for the suggestion and also the G tools suggested.
I m still cannot find out why I can't use the .NET component after upgraded LabVIEW 8.5.1 to LabVIEW 8.6. Hopefully some1 experienced it can lend me a hand. Thanks.
Message 4 of 11
(5,923 Views)
Hi Engwei
I have found out that this is an issue that has been previously discovered. The .NET marquee progress bar doesn't function when stand-alone, although as George Zou showed, by wiring in an event structure afterwards it is still possible to create a fully functioning progress bar - thanks, George! To my knowledge, there are no such issues with other .NET components and it is rare to come across a problem of this kind, so I hope you won't be put off using them in the future. Can I just check though, was the .NET component working in LV 8.5.1 prior to the upgrade to 8.6? Hope to hear from you soon,
Best regards
Jeremy T
Technical Marketing
NI
Message 5 of 11
(5,904 Views)
Hi Jeremy,
Thanks for your time.
Ya, the marquee work well with LabVIEW 8.5.1, before I installed the LabVIEW 8.6.
After I install LabVIEW 8.6, both version of LabVIEW can't run the marquee. And before I install LabVIEW 8.6, I din't do any software installation on my laptop.
The vi I previously attached don't show the animation, but if I run the vis, an error will prompt out. If run on no-trouble LabVIEW, no error will prompt out.
To show the marquee run continuously, you can run the vi attached.
Ability to integrate with .NET component, in window platform sounds important to me, and those windows component's fans. So, hopefully we can solve it up. Thanks again.
Message Edited by engwei on 11-25-2008 08:00 PM
Message 6 of 11
(5,883 Views)
Ok, I was confusing, and I thought what can be done in LabVIEW 8.5 should be no problem in LabVIEW 8.6.
Thanks for the VI attached.
Message 7 of 11
(5,857 Views)
I run the attached vi by zou, it work properly in my LabVIEW 8.6.
I copy it and save in simplemarquee_same.vi. I try to run it. But the same error prompt out.
And I really don't know what is the problem. Can some1 run the vi attached here in Labview 8.6.. Thanks.  And, what is the causes ?
Message 8 of 11
(5,855 Views)
Accepted by topic author engwei
The problem is that you didn't set you VI to run in UI thread.  Either you didn't see my comment in my attached VI, or you don't know how.
Assume you don't know how.
See attached png image for set up you VI to run in UI thread.
George Zou
Message Edited by zou on 11-29-2008 04:34 PM
George Zou
Message 9 of 11
(5,820 Views)
Oh thanks for your attachment.
I repeatly look at ur comment "1. make VI run in UI thread" in your vi, but I don't know what does it means. And in 8.5 I no need to set it.
Thanks for your answer.
Message 10 of 11
(5,791 Views)
