.net ping
 I'm new to labview. I'm uisng a .net ping fuction that I found on the forum and I'd like to know if the program is using the following MS function. Please see attached
http://msdn.microsoft.com/en-us/library/he5sca5t(v=vs.90).aspx
(3,216 Views)
No, it's not using that VisualBasic function. It's using this .NET class:
http://msdn.microsoft.com/en-us/library/system.net.networkinformation.ping(v=vs.110).aspx
Most likely the underlying calls are identical at some point, though.
(3,203 Views)
Thank you.
(3,152 Views)
