.net remoting
Hi everyone!
I'm a newbie to the .NET world and am trying to write an interface to a 3rd party Gauge using Labview and .NET, and am being very unsuccessful. Currently all I have is a reference to a .Net Class that's tied to a property node to read a dbl. When I run this application I get the following error:
Error 1172 occurred at Property Node in Untitled 2
When I talked to one of the software engineers who supports the Gauge software he said that in his apps he has to define a port. He does something like CGaugeUtilites.m-vSetupRemotingChannel(I32, string) were I32 is a port in the neighborhood of 57500 and the string can be anything. I tried to do this with a constructor and property node before I tried to read the dbl with no luck. Does anyone have any ideas how I should go about solving this problem?
Thanks in advance!
Matt
(2,978 Views)
Hi Matt,
What version of LabVIEW are you using?  Where is your VI and .NET class located on your computer?
http://digital.ni.com/public.nsf/websearch/F326A891E72073B486256EEC0006E019?OpenDocument
http://digital.ni.com/public.nsf/websearch/B15CE9F2715434C386256D3500601878?OpenDocument
http://forums.ni.com/ni/board/message?board.id=170&message.id=90149&requireLogin=False
(2,953 Views)
