.net warning
  I installed labview version 9 and trying to run a source code that generates report from excel file, but getting error like "Changed .NET assembly (Warning)", error detials:- "expected assembly "microsoft.office.interop.excel, version-11.0.0.0, culture=neurtal, publickeytoken= 71e9bce111e9429c ,but found microsoft office.interop.excel.version=12.0.0.0, culture, public key =
71e9bce111e9429c". So it can't load one of the VIs.
If I run the vi with microsoft 2003 no issues, but can not load with 2007 excel.
(3,298 Views)
What are the stpes to reproduce this error?
(3,264 Views)
Solved the problem. it was missing a sub vi under "C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\Utility". I copied it from the web and it is working now.
(3,251 Views)
Er... what do you mean you were missing a VI from the <vi.lib>/Utility directory and you "copied it off the web"? The VIs in that folder come with LabVIEW. Are you running a legal copy of LabVIEW?
(3,248 Views)
