network bound variable on daqmx channels
Hi all,
I have a VI that runs fine reading data through Daqmx.
I also have a 2nd vi running on another pc that has network shared variables bound to some digital in daqmx channels on the 1st PC.
The problem is if i run this at the same time as my 1st vi,my 1st vi no longer processes the digital inputs (i.e.i switch to on and off and nothing happens), do i need to create network shared variables that i populate from the daqmx ones on the first pc and read those across?, im just wondering if its because you cant read the daqmx channels through the daqmx vis and also try to read them through network bound variables?
hope that makes sense
Mike
(2,660 Views)
Duplicate post.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,632 Views)
