network connection name
Hi
Is it possible to get the name of network connection icon(refer to the attached pic) through program based on ip address?
Pls let me know if there is a way.
Thank you.
(4,369 Views)
I think the .NET example VI located here will give you what you want...
http://decibel.ni.com/content/docs/DOC-1089
(4,332 Views)
You should also be able to get this information by using System Exec and issuing the command "ipconfig /all" and then parse the output. Not sure which is better for Vista, though, which is what you seem to be running (and for this, my condolences Smiley Very Happy).
(4,318 Views)
I would guess, that info is stored in the registry. You can try searching for the name to find the keys.
Felix
(4,308 Views)
Accepted by topic author rdtttttttttttttt
Here is a more comprehensive VI to get all named adapters, and the ip addresses assigned to each...
(4,302 Views)
Hi guyz
Bravo! Bravo! I did not expect such an elegant solution. Thank u very much!
Btw, another question: How can I change IP of a certain IP using dotnet in Labview?
(4,291 Views)
rdtttttttttttttt wrote:
Hi
Thank you.
Another solution which does not invoke the entire .Net resource hog, would be posted in this thread.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(4,278 Views)
