network frontpanel publishing
Hello!!!
I am trying to start to design an application which can be controlled from different PC´s in a network.
The idea is to have a MASTER pc, which gives the permissions to access to the application to some other PC´s.
I do not wanna let the internet accesing; I just wanna access through a local network.
Can anybody give an idea to do that? Could you say me where can I find some information about?
This is the first time I try to do something related to a network.
Thanks in advance
jm
(3,211 Views)
I just finished building an application like this.
We built a local network (some computers had two ethernet cards so they could access the corporate network and/or the internet).
We communicated between PC's using the TCP/IP vi's.  Each PC was assigned a fixed Port Number so that they could only talk with the Master PC.
Is that the kind of thing you were thinking of?
-Matt
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,201 Views)
Hi!!!
Thank you very much. That is just what I want. I am going to investigates these TCP subvi´s.
In my case, the master should give some permissions to the rest of the pc´s to let them to
access to the application.
Thanks in advance.
jm
(3,192 Views)
What I did for that was to make a cluster, flatten it to a string, and send the string via TCP/IP.  Then on the other side, I would reverse the process.  Permissions could be one element of the cluster.
-Matt Bradley
(3,189 Views)
Hi Matt!
Have I to define in any way the application to be published into other computers? I mean,
must I define any property of the VI to be published?
Could you give me an example of your application?
Thanks in advance
jm
(3,156 Views)
