network stream AvailElmntsForRead return bad value
I'm doing some test with network stream , i'm using networkstream with array of 500 double as element.
I write 2 elements (2 array of 500 on the stream) . Then wait that element are written.
Then i check the reader for AvailElmntsForRead. The value of this property must be 2 but is actually 500.
I've checked the documentation but i don't find any explanation for this.
Regards
Message 1 of 1
(2,758 Views)
