network utilization information like what windows task manager does
Hi all,
i want to use labview to get the network utilization information just like the windows task manager does.
so how can i get the network utilization(like 19.8%), link speed(100M/1G) and state(connected/disconnected) info using labview?
thanks a lot!
(4,088 Views)
I'm sure there are some .Net components that allow to do this but I would personally use the Win32 API directly though the GetIfTable() API in IPHLPAPI.DLL, https://msdn.microsoft.com/en-us/library/windows/desktop/aa365943(v=vs.85).aspx.
But that is already quite advanced programming and not very suited if you don't know quite a bit about how to call that function from C and also a bit about C compiler specifics when it generates code to call such functions.
Another option would be to call the Performance Counter API  or the WMI API. But both of these are even more involved than the above.
Rolf Kalbermatter  My Blog
(4,064 Views)
Thanks a lot Rolf Kalbermatter! I used the performance counter functions and everything goes well! thanks again!
(3,931 Views)
