new window and button
What is the best way to open a new window after press a button?
Here is what I have tried to do.
Tks
Fernando
Message 1 of 9
(4,245 Views)
Go to the VI properties of the subVI.  Window Appearance.  Customize Button.  Select Show Front Panel When Called.
Message 2 of 9
(4,237 Views)
Thank you very much Raven you helped me a lot
Now if I want back to the menu. What I have to do?
Tks
Message 3 of 9
(4,226 Views)
what I want to do is...click on button and close the prog.vi.
Message 4 of 9
(4,224 Views)
Well, you don't have a button on the subVI to click on so the first thing to do might be to actually add one there.Smiley Wink
Put a while loop in the subVI and wire the Boolean to the termintaion terminal. This is extremely basic stuff (and also covered in the shipping examples). You should spend some time with the tutorials available at http://www.ni.com/academic/lv_training/how_learn_lv.htm
Message 5 of 9
(4,217 Views)
I did what you suggest but it did not work.
Take a look on it
Message 6 of 9
(4,211 Views)
In the subVI's properties, you also want to 'Close afterwards if originally closed' and you don't want 'Show front panel when loaded selected'.
Message 7 of 9
(4,197 Views)
which is the best way to close a sub vi? use what you explained or use FP close?
Tks
Message 8 of 9
(4,175 Views)
That depends. In your case, where you want a simple popup, I don't see any reason to use the property.
Message 9 of 9
(4,170 Views)
