newbie trouble setting up pressure sensor
Thank you Minions, that did it!! Switched the negative power supply lead to the ground plug and it is working. Still doesn't work using the 9237s internal 10V excitation but not worried about that. Thanks again. Embarrassed it was such a simple issue in hindsight but glad to have it figured out.
Message 21 of 23
(1,021 Views)
The 10V excitation on the 9237 device can only drive up to 150mW.  This means that the total bridge load (across the excitation points) including the sensor must be more than 667 ohms.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 22 of 23
(1,015 Views)
Yes, that would be why. Thanks again. Lot to learn here on my end, appreciate all of the help from everyone.
Message 23 of 23
(1,011 Views)
