newly written tdm/tdms file not found
I am trying to save some simple thermocouple data to a tdm/tdms file.  I run my vi and it seems to work just fine. I am using the NI 9213 getting started example as a basis and have added tdms open, tdms set properties, tdms write, and tdms close.  I can see the data streaming on the waveform chart but when I hit stop and go look for the saved file I can't seem to find it.  What am I doing wrong?
Thank you
Message 1 of 21
(5,293 Views)
Can you share your code?  Are you getting any errors?
A total shot in the dark, but it seems like when you open the TDMS file you are setting the option to Open when you really want Create Or Open.
Message 2 of 21
(5,287 Views)
I set it to create.  When I run it once for a new folder it runs just fine but if I try again I get error 6.  When I specify the folder I hit current folder. Could you tell me how to share my code?  I am new to this. I've seen people have a snippet of their code in the post.  How do I do that?
Message 3 of 21
(5,278 Views)
The easiest way is to just attach the VIs.  If there's more than 3, then zip them up and attach the zip file.
Message 4 of 21
(5,274 Views)
Message 5 of 21
(5,270 Views)
A project file does not contain any actual code.  You need to attach the VIs.
Message 6 of 21
(5,268 Views)
Sorry.  Thank for the patience.
Message 7 of 21
(5,265 Views)
You are specifying a folder?  You should be giving a full file path (like c:\temp\blah.tdms).  What you might want to do is build a file name based on the data/time.  This way you won't have to worry about overwriting files and what not.
Message 8 of 21
(5,260 Views)
I think I previously tried that but I got error 7.  I put in like test.tdms, a file that didn't exist because I assume its going to create it correct?
Message 9 of 21
(5,257 Views)
If the folder that you chose doesn't exist yet, then you will get an error.  Can't tell you how many times I ran into that problem.
Message 10 of 21
(5,251 Views)
