next iteration on click
I'm trying to make a loop (while or for) which I'll be able to control so it won't go to the next iteration until I click.
I tried using a combination with case control and didn't find a solution.
I need the loop because I need shift register/feedback node.
would appreciate help.
(3,412 Views)
You should place an event structure into a while loop without a timeout.
(3,410 Views)
Accepted by topic author nihm
Here is an example for you
(3,406 Views)
Hi nihm,
"I need the loop because I need shift register/feedback node."
In LV8.6 you can have feedback nodes without placing them in loops...
(3,404 Views)
Thanks jmcbee.
I read your reply and tried to apply it, and just couldn't figure which event is the right one...
your example is exactly what I need!!
(3,400 Views)
