ni 5640r
hi everybody,
i am aqib and currently i am using pci 5640r
i have an issue in clock setting i.e., to set my CIC interpolator
according to manula of fpga i can set this interpolator by opening "ni5640R DAC Profile VI" but i find the VIs named as "ni5640R DAC profile set value"
is it the same vi through which i can set my interpolator?
Regards
Aqib
college of aeronautical engineering
Risalpur
(2,299 Views)
Hey Risalpur,
The correct forum for this post would be in the IF-RIO section.  The people in that section would be able to answer you more completely.
I did download and install your driver though and I couldn't find the DAC Profile VI anywhere.  I looked at the profile you mentioned and it does seem to configure the CIC Interpolator, so I would guess that would be the VI to use.
Jake G.
(2,282 Views)
