ni 6008 single digital pulse generation
I want to use NI 6008 to generate a single digital pulse on demand (not a pulse train). I guess it won't be very difficult, but I don't know much about Labview. Could someone write a VI for me? Thanks and I really appreciate any help.
Jie
Message 1 of 8
(4,832 Views)
In LabVIEW do Help -> Find Examples.  Do a search withing find example for "digital pulse" and select VI Gen Dig Pluse.vi
Try this link:
http://zone.ni.com/devzone/cda/epd/p/id/2721
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
Message 2 of 8
(4,821 Views)
Thanks. But I cannot run the file downloaded from the link, cause many sub VIs are missing. Also, the Gen Dig Pulse.vi cannot find any port. I am new to labview. Could you give more hints? Thanks. By the way, I am using Labview 8.0.
Jie
Message 3 of 8
(4,814 Views)
The example I sent you needs a counter that is not available on the 6008.  That do you want as far as duration of the signal.  Is it critical?  You can send a very simple high and low using a software timer.  Attached is a very simple digital pulse.  You need to select the line to generate the pulse and the delay between high and low.
Matthew Fitzsimons
Message 4 of 8
(4,810 Views)
The pulse width will not be very critical. We want it to be ajustable on the order of several milliseconds. Your VI cannot not be recognized. Could you sent one for Labview 8? Thanks for your help.
Message 5 of 8
(4,808 Views)
Version 8.0
Matthew Fitzsimons
Message 6 of 8
(4,791 Views)
Thanks, that's exactly what i am looking for.
Message 7 of 8
(4,783 Views)
No problem
Matthew Fitzsimons
Message 8 of 8
(4,780 Views)
