ni 6520
I currently using the PCI-6520 Dig I/O card and is running out of digital input lines and also running out of PCI slot on the PC. I was looking at the PCI-6528 and wondering if it can be used a compatible DIO card in place of the 6520.
(2,669 Views)
Hey,
I assume you allready had a look on the product description of both of the cards. So in kind of compatibility it would be necessary to know what should be compatible? If you need to use the same cable or connector....no, if you need to switch 2A...no.
I would suggest you to call you local NI Office where they can give you the best help regarding the specifications you need.
Christian
(2,657 Views)
