ni Scope dll not found in LV 8.5
Dear All,
The History:
My test station with more than 1000 vis work well in 8.2 full Dev System now I have to upgread to 8.5 full dev system and now I have Problem.
ISSUES:
The ni Scope Error Vi says Get Error function Not found in ni scope.dll. I have Install the lastest ni scope 3.3.1 and still the error is there.
Kindly see pics.
CLAD
Certified LabVIEW Architect
Certified TestStand Architect
(3,291 Views)
see pic 2
(3,289 Views)
See pic 3
(3,275 Views)
Dear all,
so no solution from any wire worker..........
I did it myself........
Solution:
when you upgrade from 8.2 Application with ni scope 2.6.0 to 8.5 you will have the same issues that I have this is becouse 8.5 does not support
ni scope later than 3.3.0. What i did after some hours of reserch is to upgread my scope vis to 3.3.2 and then I had no more problems.
have fun wireworking .Smiley Very Happy
CLAD.
(3,241 Views)
Dear ohiofudu,
sorry for the late reply.
Yes you're right: The description at the NI-Scope 3.1 download page is capable of being misunderstood:
NI-SCOPE 3.1 Minimum Application Development Environments:
 - LabVIEW 7.0 or later (LabVIEW 7.1 required for NI-SCOPE Express VI)
When you look at the Release date (06-2006) you can see that this driver is a bit older. At this time LabVIEW 8.5 was not yet available.
I'm glad hearing that it works now with the (quite) actual NI-Scope-driver.
Sorry for this inconvenience.
With best regards from Germany
Ralf N.
Appplication Engineering
(3,228 Views)
