ni cdaq 9137
Hello! I have a ni cDAQ 9137 module and I want to install Labview 2019 in it. Can you tell me if it is possible to install labview 2019 in ni cDAQ 9137. Thanks a lot!
(555 Views)
Hi nho,
The cDAQ9137 is not a "module", it's a chassis with an embedded controller.
Which OS do you run on this controller?
Maybe all you need is to check this list!
(538 Views)
