ni daq usb 6008
Hello every one...
           Iam strucked in one problem.that is i have been developed one program with NI usb 6008 daq board in my laptap.But this build aplication i have been installed in another computer,then the board is not performing any action as per program..so seems like any thing have to inatall...
      Thank you....
(3,430 Views)
What are drivers have to install of ni daq usb 6008 in computers..
(3,397 Views)
Accepted by topic author hanumeshbujji
Hi hanumesh,
you need to install DAQmx to use a DAQmx device…
But even better: You don't need to install drivers on your own! All you have to do is to create an installer package with the AppBuilder, which includes all needed drivers.
Another topic are settings made with MAX: you need to copy such settings too. That's why I recommend to have such settings either in your VI or atleast with your project instead of having them in MAX…
(3,376 Views)
Thank you...
(3,367 Views)
