ni elvis II+ oscilloscope
I keep getting this error trying to run the oscilloscope "Error -200077 occurred at Property Node DAQmx Timing (arg 1) in ELVISmx_subScopeAcquire2.vi->ELVISmx_subScopeAcquireData.vi->Scope.vi"
anyone with suggestons?
Message 1 of 9
(3,450 Views)
looking at the possible reasons for this error:
Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Check if your property is supported:
Error -200452 DAQmx Property Not Supported or Applicable
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MPKSA2&l=en-US
Message 2 of 9
(3,411 Views)
Version 19 of the software was the problem. I went to version 19 for the ni elvis ii+ and it worked fine.
Message 3 of 9
(3,394 Views)
Did you mean that it was version 18 that still works?
Message 4 of 9
(3,333 Views)
excuse me which version worked for them, 18 or 19
Message 5 of 9
(3,312 Views)
Version 19 created an error when using the oscilloscope. I installed version 18 and everything worked fine.
Message 6 of 9
(3,290 Views)
Sorry version 19 gave an error when using the oscilloscope. I installed version 18 and everything worked fine.
Message 7 of 9
(3,287 Views)
In my case driver 19 has the same issue. The error appears only with the scope channels, ai channels work properly
Message 8 of 9
(2,847 Views)
Hi Manushak,
What happens when you follow the recommendations given in the error message and request more than just one sample?
Message 9 of 9
(2,839 Views)
