ni-max plot bit from U32 bit field
Is there any way to plot a single bit from a U32 bit field in MAX?
(3,059 Views)
MAX is a configuration utility that is used to verify operation of a device. Because of that, it has only basic plotting features to be used for confirming signal levels. If you need to plot single bits, you would need to use LabVIEW or some other environement in order to acquire your data and then get the display you desire.
-Zach
Message Edited by Zach H on 06-22-2009 01:00 PM
(3,029 Views)
